As standard the 3B only has a 1 bar ( 200Kpa ) MAP sensor, so most off the shelf chip sets for the 3B only allow 1 bar of boost. If you need more and you will need to fit the MAP sensor from an ABY which will allow 1.5bar boost, this sensor will have 250Kpa on it.
I took my s2 to mr collins and the car does run well but more is required. So max chip is only a 1 bar map then.
I take it the question I should be asking them is if mtm to a bigger MAP sensor to get 20 psi or remove mtm and replace with forum recommendations ( one as Andy was mentioning )
I think im running pretty much the same set up – MTM derived chips designed for a standard 3b map sensor – so the most I see is also about 15psi. Had a bit of a wild goose chase as I used to see slightly higher levels (18ish psi) but have generally come to the conclusion that it must have been down to some oddity that has sorted itself out now!!
Really happy generally with performance at present and the chips truly transformed the car from standard - but ever since Ive got it into my noggin that Ive “lost” a little boost Ive been toying with the idea of uprating to a 2.5 bar map sensor set up, if only to bring the 3b more in line with the performance of a chipped ABY, if that’s possible. But - as per the thread - what’s the best option! As has been pointed out before they are a lot of bad chips out there, which makes me wary and still debating if its really worth it, whilst keeping an eye out for a possible 3b homefry option which is probably the best way to acheive this!
But - can you transplant an ABY map sensor into a 3b ECU? – I thought unfortunately it wasn’t that simple!
Paul
Trick Pearl White 1992 3B S2 Coupe. Porsche 996 monoblock stopping power! HID Seeing power! Mmmmm Miltek!!!
Trick Indigo Pearl B5 S4 Recaros, Bose , Mmmm Miltek!!!
Paul
Hey Paul
I will spk to Mr C at QST today / tomorrow and get the low down on what can, cant be done from a QST remap as in can a bigger MAP sensor be "plug and played" and other details related.
Will post details as to get a bit more pre new turbo`s etc has got to be a winner.
At the moment I am thinking
Bigger Intercooler from carstens link < £200 and fits straight onto 3b XM
Samco`s from Mr Nugent
RS2 metal gasket as recommended by above
and pending QST a slightly bigger MAP to give 1.3 - 1.5 bar so a healthy 18 - 20 psi
That I reckon has to be the most cost effective way for more beans .
MB-Cartuning can recalibrate a 3B or an ABY map sensor to 300kPa for 80 euros. I think this is what Minhea does as well when a 3B is remapped, albeit to 250kPa.
